Hard Tops
- Capt.Frank
Hard Tops
I am working on getting a hard top build to replace the canves on my boat. JP and Capt. Patrick (Hancocks boat) have what looks like 12v foward and aft LED flood lights and a 115v flood in the rear of the top. Does anyone know the brand of lights ? Money is tight so I am thinking I might add those lights later. I am planing on one LED over the helm and just leave my 12v lights on my tower for now. Was just curious to the brand and price of those lights. Anyone know what lights people use when they put the runing lights into the hard top. I love that look. I plan to help and do some sanding and work on the top to cut costs.
1976 FBC
3208 NA
3208 NA
Capt Frank...
I considered replacing my old canvas type top with a hardtop but decided to remain with a soft top because I read that if you leave your top on in a hurricane/heavy blow the wind gets under the top and causes the boat to heel, presenting more wind resistance. Boats have been known to drag anchors or been pulled hard against a float or pier because of this, causing damage.
My new soft top has the normal grommets every 6" or so, and instead of threading a single line through the grommets and around the pipe frame I use electrical wire tie wraps. In a rush I can cut them and have the top off the frame in just a couple of minutes.
Capt Frank (the other one)
I took my new Hella 120v aluminum floods apart and used TefGel on every screw, etc and years later they come apart real easy to change the bulbs. Without the TefGel they would only last a couple of years before the dissimilar metals corrosion would peel the powder coating off. TefGel eliminates that. And the Hellas are actually pretty good lights - stainless fasteners - and cheap.
- Capt.Frank
Guy's,
The L&H 33 express that I am surveying right now is using Lumatec brand LED's they look like thet are pretty good quaility and they also make an underwater LED that is about half the price of the nearest competitor. The web site is www.Lumateclighting.com.
Pete
Pete
- Capt.Frank
Users browsing this forum: Briancc, Google [Bot] and 62 guests
