Barbara Jean report # ?
- Russ Pagels
1972 31 FBC 315-141-1226
is that good men do nothing.
yep and it is critical on a 31 bertram i can even feel the differance when i try to hide that offshore anchor and chain in the chain locker. i think 50 lbs in the nose is worth 400lbs after the main bulkhead. the prop. shaft angle constantly pushes that bow down don`t put weight up there to help it along. they only make bow planes for subs not pleasure boat. ask capt .patrick about ruddering. make sure waste tank is in engine compartment yea its a bitch but essential!!
i believe it is a 330hp cummins powered boat. my post is in general to all this particular boat may be perfect .what i am saying is the lever effect that is 50lbs eight feet forward of balance becomes 400 lbs on the front part of the "see saw" hard to make up unless you have 3208 catapillar for power. fbc in a 2' to 3' sea wants to have waves cresting under front of side windows at cruise speed with the boat slightly bow proud .most effective when coming in a inlet riding the waves in .ruddering will cause dangerous condition of bow being push to one side or another.
- Russ Pagels
russ 22 to 25knt. is well within the scope of my discussion that is exactly the speed i was indicating. the fact is 99% of 30' boats that have a head locate the holding tank immediatly adjacent to the toilet. so we have a toilet , 20gallon holding tank, anchor@ rode,storage under v berth equating to about 8'from balance point. . 8 x 210 lbs (assuming a full holding tank at times) equals 1680lbs effect on the bow of the boat at cruise speed of 22knt not 90kns . the only way to nolify balance is to hard pipe from head to holding tank located to the stern of main bulkhead. this is not my 2 cents this is base on many hours of operation with 31 bertram.
For the discussion of leverage yes the bow is affected by less weight than it takes to make the same change in the stern.
For the discussion of ruddering, this boat won't be fast enough to see that effect. The boat was sea trialed with this layout and has been running this way for years- like 15.
Running angle may be different than a balanced boat but it will be safe and dependable like the rest of our 31's.
Don't worry Russ the sky is not falling. If your worried keep one less fat guy in the V-Berth.
there was no intention to alarm anybody just make them aware of raymond hunt design . i did not put the little white signs on the side of the gunnels " slings" that was the original desigh balance points of the factory. the point is altering it has limits one way or the other to maintain safety however at this stage of contruction no big deal to run a 11/2" pvc pipe to holding tank and flexible waste hose on each end and keep holding tank out of sleeping/eating quarters ---just sayin ! never seen a odorless holding tank.and at the same time increase fuel milage by decreaseing wet area.
Users browsing this forum: Bing [Bot], Google [Bot] and 42 guests
