calling Bob Lico
- Russ Pagels
calling Bob Lico
Bob could you post some pictures of your fly bridge top. I need ideas for mine.. thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
I ask myself what i really wanted then went about observing likes and dislikes on a couple of hundred existing boats. 1) the radar arch must have a inner rail around the entire radius for me to use as a grab handle either accenting to the bridge or handing a rod down to the mate below. 2)the radar arch must be built super strong with three attach points (one for wireway) to install a open array radar. 3) no attach points in front of bridge for typical alluminum vertical bar (wishbone).4) for cruising in bays and rivers or nearshore i want to be able to a,remove front curtain b,remove side curtain c, fold back top to radar arch or any combination of the above.
thank you peter . you can make out the fore to aft surport in second photo. russ just pull ss pins and surport drops in your hand. also have aft stamoid cover to totally enclose bridge with heat coming from below so we operation going to offshore wreck in january at 10 degrees and all off in august with 100degree heat index. and option to leave top on with a/c thru vents .
- Russ Pagels
russ there is a 1" foam rubber strip that follows the front canvas all the way around that foams a seal between fiberglass of boat and canvas. waves in excess of 10' will break on front brow and follow curveture of boat some water come in bridge without seal depending on speed.
my boat rides quite differantly . very bow proud in rough water after backing off . the seal prevents the water that rides up the front of bridge from coming in between canvas and fiberglass is is not going to stop a wave going directly into it but then again to hit a wave like that would mean i was going way to fast. patient; stay in that perfect angle and go over the wave not thru it . cannot blame the boat for" pilots error".
mike look at 1st picture chine is in water with no fuel in boat . with fuel chime is 2" under water at stern . i would venture to say there is a differance of 1000 lbs in weight shift differance between yours and mine .starting with engines,gears,gen,holding tank, anchor,28' of heavy chain all siting in cockpit with no tabs pushing up at all times, she lays into the big waves at 15knt.
Russ,
A suggestion use full zipper off track on the bottom of the enclosure- it can be bent with a heat gun to conform to the boats contours (the way your bridge has been modified the angles are even less severe), no buttons no silly foam pads- no bullet holes in the enclosure. Every button in an enclosure will allow some salt water into the layup, after a hard rain you will see more noticable black streaking from these metal connections as they age.
Be cautious about putting buttons and snaps in the aluminum, if you don't exercise the connnections every month they will seize up, try and use zippers for as many of your connection points as you can(yes its more work for the canvas guy) the zippers should be maintenanced every month as well there is a specific cleaner and lube for the zippers but the product name slips my mind right now.
Remember stainless and chrome over brass buttons, murphy snaps and lift-a-dot connections will only add another corrosion point to your aluminun frame the less canvas you wrap around the frames the longer the finish will stay on the aluminum.
mike i know you don`t have tabs but perhaps a live well at the transum might help . you could empty it and just use it when weather turns bad. this year when those big bluefin tuna come in for the annual migration of "white snakes" both you and brewster will come aboard because normally the the waves and weather are bad during first week of november you pilot and see for yourself. brewster will teach us how to nail the most elusive fish i have ever seen during this time of year.i hear nj has the same seen at the sea girt bluefin with lockjaw.
- Russ Pagels
Here's a few Russ, the original guy that did our top is back in business (not his son) but you'd be best if the boat were back up this way if you wanted to go that route.
The first shot is the inside finish with a zipper off track bottom
This shot will show you the outside finish with the zipper off top and bottom
This is a decent shot of the top and the lighting layout flushed into hardtop
This shot is a decent profile, you can see the advantage to zipper off track in how clean the top and bottom of the enclosure lay (no bullet holes)- pay attention to how the outriggers follow tops piping, notice that the break arm follows the same angle as the riggers, most people have a tenadancy to skip this step either because they don't know or don't care. The enclosure should follow the angles of the top as well (you can see that the side curtain follows the back leg. If you can get away with it has the canvas company sew the clear to itself instead of adding a piece of stamoid to the seam- its just cleaner, this enclosure is acutually 3 pieces of strataglass sewn together just no stamoid seems.
If your going to use a center rigger the best results are achieved by pointing it up in the air, if it comes off the top close to a horizontal angle it will be no higher than a rod fished out of the launcher on the bridge (notice the spinning rod tip). The top your looking at is as low as we could go without hitting our heads, the effect is a little better proportion.
- Russ Pagels
There are two non skid pads on the outboard side of the flybridge. We just jump up either side and slide in between the aft leg and the enclosure. Even the older guys (mid to late 60's) have no problem getting up and down, when its shitty just go under the rail.
No ladder gives us 2 big beds for those long rides and instant access to the engines for periodic checks during the fishing day. Its not for everyone but you get used to it.
Anybody can build one of these things but its all about the details that make them truly special. There are allot of beautiful B31's with really ugly aluminum and enclosure work, just make sure you take the time to get her the way you want her. Good Luck.
jp we both have that zipper half circle facing bow. i hate that feature in november/december striper run you get to boat in dark and all cover in dew . go to roll up and stiff as a board . would like to somehow have that everglades windshield material almost the feel of lexan so you can pull up in one piece like window and faster to the bottom off hard top in your case or soft top in my case. i like the plastic slide that is how the soft top is attached to the radar arch . if i use your method of slide on bottom i guess it means i cannot remove the entire front section in summer and leave side curtains. am i right?
If your enclosure is 3 pieces- 1 front and 2 sides then all you are doing is replacing one fastening method with another. The material attached to the track is done with zippers look at the interior shot I posted again and you'll see the attachment. You could take off whatever pieces you wanted whenever you feel like it.
The hard glass is ever than regular 40 ga. sheet glass so if you were to fold it up onto a soft top you'd have to sew in some support fabric so you wouldn't get a tear at the attachment point.
The hard glass lasts about seven years you can get the same out of soft with extra care. The weak links is still the thread, maybe I'll try powerpro this time instead of gore tex.
I rigged mine to hang under the bimini top. No more scratches from rolling it up and no more fighting it when it is cold and stiff.
Eddy G.
[img][img]http://i232.photobucket.com/albums/ee10 ... C00031.jpg[/img][/img]
Eddy G.
Users browsing this forum: Pete252 and 18 guests
