Propeller help
Propeller help
I currently have Yanmar 6BY260 engines with 2.43:1 gear ratio. I am wondering which would be the right prop ( diameter, pitch, 3 or 4 balde) for that combination.
- Gert van Leest
Then you can add an inch of pitch (-100) and add some cup (-50). Both can be done with your original props at a good prop shop. Talk to them. You might get the same results with a super cupping that would work at your top end. To me, if you're going slow enough at idle and don't want to go any faster (re slow trolling), cupping may be the way to go.
Careful, those engines are rated at 4000 rpm. I've read that the new electronic governors won't rev much over rated like the mechanical ones do. On a mechanical engine, it is recommended to prop around 150 rpm over rated with a fully loaded boat. So at 4000, you may be underpropped. But if you do add pitch or cup to your props, be sure you don't get below 4000 rpm fully loaded. http://us.yanmar.com/products/marine-en ... /6by2-260/
Eddy G.
Eddy G.
- Gert van Leest
if you have the first series of BY 260 ( whit the plastic covers ) add an extra inch of pitch and you will be fine.
If you have the second generation of BY 260 ( with the steel covers) you can add a litlle more pitch.
The second generation gives a little more HP (10-15) and has a different power curve.
Ive build in over 30 of these engines , believe me !!
Regards Gert
Regards Gert
- Gert van Leest
Users browsing this forum: No registered users and 23 guests
