Looking for a Bertram25 1962-1972 Hard Top V-drives
Can anyone help me in my search for a Bertram25 1962-1972 Hard Top V-drives PROJECT BOAT. Will consider a boat with a flying bridge.
Email me at nolan0874@aol.com or respond to post.
Thanks !!!
Thanks !!!
There is a B25 hard top on the lot at Chesapeake Yacht Basin in Kilmarnock VA. 804-436-1234. Not a project, it looks to be in very nice condition. Not sure of the power. Let me know if I can help.
Bertram25 Thank You!
Thanks guys for all of your help...I'll let ya know if I can use anyone's help...keep em coming!
Matt-
Matt-
fred....the first time i tried to change the plugs it litterally took all day (same 360's) the trick is the right tools and dont even try to look....can do all 16 in less than half an hour.......my trick is a stubby pressed steel open end wrench like you would have for a skil saw or a router....and one of those plug sockets with a hex head....you can manuver the wrench up and down as well as back and forth....once loose i use a regular socket with friction tape on it to get the plug out and turn in the new one after hand starting.....took a few times to learn the proper angles without looking....and i dont over tighten the plugs......now shaft alignment....after 10 hours i called in a pro........and anyone who knows me knows i had to be pretty desperate to do that
Randall,
Sounds like you are confirming what I once heard about V-drive boats;
"You must have faith to own a V drive because you can't see anything and faith is required to believe that there is a shaft and packing down there somewhere"
Users browsing this forum: Google [Bot] and 356 guests
