UV Ribs
UV Ribs
Ok UV tell me how to cook pork ribs your way on grill.
Okay Brew.....rub them with sea salt and put them on the indirect end of the grill, uncovered, meat side up. Close the lid on the grill and keep the heat about 225 degrees. Use a small firebox on the hot end of the grill with some hickory chips for smoke, change the chips now and then.
The Sauce.......ahhhhhhh, the sauce....been in my family since before The War of Northern Agression......
Take a saucepan and melt three sticks of original Parkay and add some olive oil to the melted Parkay, say the equivalent of a couple more sticks. Add the juice of at least 4 lemons, then slice up fine the peel of two or three of the lemons and add to the pot and simmer. Add two tablespoons of sea salt and two tablespoons of soy suace, then press in a lot of fresh garlic, say a whole head, continue to simmer - the trick is to cook down the lemon peel to a mush. If it looks too thick, add some more olive oil, if too thin, add some more chopped lemon peel - a food processor will chop the woo-woo outta the peel, but its better thinly sliced and hand diced. Keep slowly cooking down the sauce as you use it, adding a little olive oil if you start to run low.
Let the ribs cook an hour or so unbasted to let the sea salt make a rind, then baste the ribs frequently with the sauce as they cook. Cook them for 8 or 10 hours......after about 6 hours turn them meat side down and baste the bone side, let them cook that way for an hour, then flip 'em back over, continue to baste to keep them from drying out. They are getting toward done when the bones start to stick out. As long as you keep them basted real good they are hard to overcook.
Buy ribs with a lot of fat on them - grocery stores in the ghetto have the best. Stay away from "lean" or "heart healthy" shit. We cookin' ribs here, not dieting.
Hey Brew, I'm cooking two racks right now, been on since early this morning & they sure look & smell good....in fact, smell so good I may have to move the pit behind the fence since its garbage day and the democrats on the back of the truck keep circling the block....like hunting over a baited field....
Users browsing this forum: Google [Bot] and 446 guests
