Engine weights
Engine weights
What is the weight of a BBC gasser vs a Cummins 6BTA?
I'm not looking for exact weights, just ballpark... They're pretty close right?
that is a loaded question . we must add the gear weight with it for comparison. the cummins 6bta comes with zf 220 irm gears that weight 65 lbs and the big block comes with cast iron b/w 70 or 71 series about 160 lbs so the cummins at 1150lbs plus gears around 1215lbs is just about equal to big block.after 1000 test the answer is the 31bertram fbc needs about 1400 lbs after main bulkhead to be in perfect balance ,that is water line even with chine at the stern so you need to put something either under cockpit evenly on both sides like generator,holding tank, ballast whatever.
Users browsing this forum: No registered users and 19 guests
