Headliner repair
Headliner repair
Not on my B31 but the old Tahoe....the brake light on the top of the vehicle got busted by a falling limb and water leaked into the headliner causing the glue to fail and it to sag. Someone recc'd 3M two sided tape but it won't stick at all, even after scrubbing the metal top with lacquer thinner. I've used the 3M spray automotive contact adhesive on my Soundown with good results, but its gonna be difficult to get the spray inside the sags.....but I guess I can cut the sags open with a razor, spray, then lay it back in?
Its a 97, but low miles and we keep it around as a spare vehicle so don't wanna spend a bunch getting a new headliner put in.....on that subject, anyone got a guess how much a new headliner is, installed?
Have you tried Contact cement? If applied to both sides and allowed to dry, then carefully bring the pieces back together from front to back smoothly to avoid trapped air bubbles (if space allows, I usually put a piece of waxed paper in between as a slip sheet to avoid accidentally touching two pieces together). This is the same stuff used to adhere Formica but is completely flexible. For what it's worth.
One of the guys in the same complex as my old Fl shop re-did auto interiors. Replacement headliners are dirt cheap and usually install within a few hours to a day.
Check: Car Body Parts
Per Rawleigh's suggestion I used my $99 Chinese nail gun and it worked pretty good, and the nails sticking out the top will keep surly democrats from loitering on my vehicle.
The outfit Andre suggested just came and got the truck and is gonna replace the headliner, pull the nails, and bring it back to me, all for reasonable money.
Going to lunch with Andre and Lyman the G-Man to celebrate.
They just brought it back with a showroom headliner, not a wrinkle, crease, sag, just like new....amazing. Didn't even ring the door bell, just left it in the driveway.....so I made a Thank You Call to the folks, something that has become a lost art nowdays. They were very appreciate of that.....we all need to remember to thank folks that do us a good job, and it will make the world a happier place.
Thanks Faithful for steering ole UV right.
Users browsing this forum: Bing [Bot], Google [Bot], jrmoro and 339 guests
