Opinions on '73 38 Bertram Widebody?
Anyone have any experience on this platform? How is the ride at speed, troll, and drift? Anything in particular to look out for in respect to this model? Any input and information would be greatly appreciated. Thanks.
Walter,
That's correct; Bertram came out with the 38' deep V hull (proportioned similar to the 31 hull) in the early/mid '60s with a 14'5" beam. Then in 1970 they continued to manufacture the same hull, but with a better proportioned house and flybridge and continued that model through the 1975 model year, then retired the hull. A few years later they introduced a new 38' model with a narrower beam (13' 3"). Ever since the intro of the less beamy 38 footer, the models through 1975 have been referred to as "widebody" 38s. You are also correct that they are tank-strong like the 31s.
Thanks for the replies. I am glad to hear they are well built. From what I have found out Tommy is absolutely correct. The '70 to '75 uses the original 38 hull which is a stretched 31. It also is wider than the later 38s which is why it is commonly refered to as a widebody. Anyone else have any experience on this model? I am curious to know how it handles, and if it has any weird quirks. Thanks again.
Widebody
The widebody is a great ride. Have fished on one many times and if i didn't have 31 now I would have the 38 as my second choice. It is indestructablle like the 31. With the orginal engines were slow but if has been repowered a great ride
Capt Bill McKinnon
Capt Bill McKinnon
Capt Bill the boat has been refitted with '92 400hp cummins 6cta's. One engine had a major overhaul (not sure what exactly) in Aug and the other one is at 1750 hours (probably will need work soon if the other just had it, but don't know). Anyone know if these are good motors for this boat and if they have common problems?
I didn't think so, but then it made me question why one of the motors needed a major overhaul already. Do you know if these are good motors and if they suite the boat well? I haven't contacted the seller of the boat yet. I wanted to do some preliminary research to see if it is something I want to persue.
I joined here at the beginning of the year to learn more about the 31. If anyone remembers I am a total noob when it comes to a big boat like this. So any help in any way is greatly appreciated, and I apologize in advance for my ignorance.
The boat is not/should not be the problem. The engines: did you mean 6bta's? I did not think they had a 400 hp version in 1992. More Cummins knowledgeable people in our group will chime in on whether I am correct on this. Back then, there were 210's, 250's (later 270's) and I don't even think the 300's were introduced yet. These were all on the same block. The 210's were turbocharged, the 250/270's were turbocharged/aftercooled, and if I am not mistaken the 300's had a different injecter pump and injecters. If I am correct, the seller may not have 400 hp engines in that big heavy boat and those engines have been overworked for the amount of hours they have been used...thus the need for rebuilding.
The ad is probably correct. They are the "6C" series, not the 6Bs....difference is the Bs are 5.9 liter in line 6s and the Cs are 8.3 liters, also in line 6....bigger displacement engines but otherwise very similar. Generally considered as good an engine as the 6Bs that many of us love. Lots of info on them on boatdiesel.com......most common cause for early hour overhauls on the 6Bs and Cs is an overheat caused by the crappy Sherwood raw water pump failures.
Get 'em checked out by an independent Cummins guy, but in my view the best engine in that class.
The Cummins 6C is a wet/replaceable liner engine, vs the dry bore block of the 6B. This makes the C MUCH easier to rebuild than a B series engine, also the engines can be rebuilt many times because no over boring is required.
In certain cases, depending on the engine room layout the C series can be rebuilt in the boat, or "in-frame".
Good engines, capable of huge amounts of hours with proper care.
Users browsing this forum: No registered users and 524 guests
