First Structural Failure
Well
After 34 years I've failed one rudder on our 31. Always thought the port rudder had been bent and straightened. Don't have to worry abouth that any more, its gone.
For those of you that have never had to steer a B31 on 1 rudder....... just be thankful they turn great to the side the rudder is on and just the opposite on the side the rudder isn't on.
Looks like an early end to the season for the CHIMERA. We'll take advantage of the time off and haul out, blast the bottom then go inside for a redo of the topsides (paint and nonskid) and replace the running gear that went bad.
Looks like I'll be fishing the Silverhawk for the fall tuna season.
JP, I have a pair of orginal rudders your more than welcome to as well, take on alot of water? That silverhawk is a great boat, had one before my 31...That boat floated..BH
Hey thanks Bob. The rudder actually failed structurally, it sheared off at the hull, no water in the boat.
I know when my brother ran the 570 (before the custom boat solution) he went through several rudders that failed the same way, only difference was his weren't 34 years old.
It'll make for a nice easy winter straightening out the hull strakes and refinishing the top sides.
Users browsing this forum: Bing [Bot], Google [Bot] and 101 guests
