In water when replacing bulkheads?
Am I thinking this too much or is it beneficial to tab in bulkheads with boat sitting in water, or just provide good keel support on the hard?
Rocky, I measured every bulkhead, took hundreds of measurements, propped n leveled the boat, and took it down to a canoe...including top cap removal....thought id have to brace cross brace and brace again...once apart...SHE DID NOT MOVE...66 model thicker hull. Leave a strong 1/4" gap along the side of the bulkheads, you dont want a hard T connection at the bulkhead tabbing..Radius Fillets are your friend the bigger the better...BH
We did engine alignment on the beach and redid it when we rested the boat in the water, these boats are stiff but we had to move my boat several times over the winter season and I had originally set the boat with the cabin sole as my level point, every time we would have to crank on the leveling jacks sternm midship ahd forward to tweak the boat back to what we thought was where we set the boat initially, the water is the bestest location
Thanks Bob and Marlin, Robbie, I am currently redoing front of engines bulkheads (sport fisherman) and rear of engines deck support, before I sister up my engine beds per Capt Pat's instructions, the boat actually sits on a 31 specific trailer so it does have support in many places bertram's haul-out support diagram dictates. Also, the boat as I own it will most of the time be on this trailer unless of course I'm using the boat...
So I guess it's "natural state" is on this trailer, not the water. I'm probably over thinking this, I don't know. I'd love to just tab'em in as she sits, sure would be easier to do so. Don't worry Marlin, I'm making it a point to follow Capt. Pat's instructions exactly!
Pat, I dont know what to say...YOU showed me the way...Ill let my work speak for itself...Thank you isnt enough.
Dug,
Coudln't think of a better foundation TO start with.
Dug,
bob i finally saw the pictures of your creation as we discuss in our conversations with harry and i. nice very nice slow diliberate meticulous planning and exercution . incidently i notice the raccors in the bilge----very cool along with the exhaust quite familar. we will talk props as next business .
- Capt.Frank
Thanks guys, its been a long road...every saturday, couple nights each week, many rainy days, five years later its getting very close...like Bruce once said...one system at a time..plan it, execute your plan..have a few do overs ( should have listened to you guys)..when its time for props I will call you for sure Bob Lico...BH
Capt Pat and/or experienced, when I go to tab my bulkheads in(after 1708 on both sides my core) am I creating the same gap on BOTTOM of bulkhead to hull as I am to the sides of hull for no hull fatigue, or does the bottom have no gap? Looks like Bertram did have gap at the bottom as well as sides on my old bulkheads. Thanks.
Bottom gap isn't as critical because of the hull thickness, the rigidity of the hull, and because it's out of eyesight when in the water. But a little gap is fine.
Make sure that your tabbing creates a nice positive radius and doesn't get tucked into the gap or make a tight 90º turn. The radius allows the flex of the boat to transistion easily through the tabbing. Use two layers of 1708 lapping 4" onto both the hull and bulkhead for the first layer & 3" for the second layer. (8" total tab 1, 6" total tab 2...)
No big secret or special technique, just let the glass flow naturally across the angle change and don't tip the brush into the joint. Use a 1" roller and let the roller dictate the radius. If the radius gets too small, use the brush to pull the glass away from the joint, then roll in the radius.
You can also hold the roller in the joint and brush the glass out and away to form the radius. let the first layer cure out to point of leather hard and apply the second layer. The radius will already be established and you can concentrate on a good tight bubble free second layer.
Practice on a piece of scrap if you're unsure, but you'll get the hang of it pretty quickly...
Users browsing this forum: Google [Bot] and 191 guests
