Oil burn
Oil burn
Good morning,
this past weekend did some canoe escorting. Took the boat to my home marina all ran fine, the next day loaded up with 12 handicapped individuals and the port motor started burning oil at 1 quart every two hours.there was a sheen in my exhaust and residue on the transom.
So my question is are my valve seals going or gone,or what else could it be.When i dropped them off and ran back to the marina all was fine.
Aloha
Aloha
1977 Bertram FBC 1688 M77L
I love it when experience gives me the ability to answer a question! Its like a full circle!
My friend, you have a pin hole in one of your oil coolers. Change it out now before you have a bigger hole.
Oil sheen in the exhaust is a given that there is where the problem lies.
Per my experience anyway. Good news is it is not a bank breaking repair, and you can do it yourself.
- Capt Dick Dean
Thanks to all.I just forgot to mention one small thing.This is a temporary..permanent fix.
As we all have dreamed.. some have completed and some not my boat goes to Maui for a set of Japan Yanmars 350 6ly-ste with zf 220 trannies.
the shaft logs will be done as rudders,shafts and pss seals also.
Cant wait for the 16th of October should be done within three weeks of arriving.the boxes have been extended and stringers glassed in. may be some small mod here and there.
Aloha to all.
Aloha to all.
Users browsing this forum: Bing [Bot], Google [Bot] and 37 guests
