strut question
strut question
just pulled the shafts on my b28(78). their diameter is 11/8" I have heard many references to cutlass bearings. the inside of the struts have a serrated rubber tube that the shafts ride in. are those the cutlass bearings? they dont seem to turn in their housing and their outside diameter is around 1 1/2". what will i need to do in order to increase shaft diameter to accomidate diesel motors? bore them out or replace.
Rawleigh's right...you can get a thinner Marine Bearing that will accomodate a larger 1 1/4" shaft.
Duramax= "BIND" code
Morse="CHOGSET" code
Both of these bearing are 1 1/2" OD with a 1 1/4" ID
You may want to download the Buck Algonquin catalog (PDF) for a source and PN reference. Look in the "Under Water Hardware" section under "Marine Bearings"
http://www.buckalgonquin.com/
Good Luck,
Good Luck,
Users browsing this forum: CHolgerson, Google [Bot] and 60 guests
