Pretty neat, I know some people play with the adjustments on their fuel senders to get them right, this is a nice thing that they came out with.
Craig Mac- this one is for you!
Autocal Fuel Level Senders
Livorsi Marine’s new microcontroller-based senders can be distinguished from our older analog style by an "A" in the part number ex: AFLS, and no trim/adjust potentiometers on the top of the sender. Senders with aluminum tubing are for oil, diesel, or gasoline of up to 10% ethanol; and senders with PVC tubing are for potable water. We do not offer units for non-potable water, which leaves conductive deposits on the sense wire.
* Senses water in fuel, lets you know by moving the gauge needle all the way to the right
* No moving parts to wear out or break
* Reading are not affected by side to side motion or forward movement
* Installs in the standard SAE 5 bolt pattern mounting plate that is used with a float arm style sender
* 2 terminal sender works on both 12 or 24 volts
* 240/33 ohms in stock
* Bendable senders are available (special order)
Livorsi new auto calibrating fuel senders, even senses water
Users browsing this forum: Google [Bot] and 204 guests
