Braze that can take salt water
On my old 504s (V8 cummins), i have a copper tube that recently corroded through that takes raw water from my engine heat exchanger over to the right side of engine to a hose that runs to the exhaust riser for cooling. I was going to fab somthing up out of copper tubing, but need to make a 90 degree bend once I hit the right side of my engine. Any suggestions on a braze material for copper that can withstand saltwater. Thinking of just brazing in a 90 degree elbow.
Giff
Most brazing material is brass alloy, something you don't want to use...
Use a high silver content soldering rod, minimum 50% silver.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/WEtUJQuK-z8?fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WEtUJQuK-z8?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Users browsing this forum: No registered users and 270 guests
