Need B31 prop advice.....
Hello all...
I received the following message by email.. I am not sure how the writer came to contact me directly, but he needs help with his props after repowering with Cummins 6Bs. It appears to me he is underpropped, but I am wondering if his engines are maxing out their RPMs against the governors stops. Can someone please post some comments to help him? I am writing to him this AM and will tell him to check here for your comments.
Hello Sir,
I'm the owner of a Bertram 31 in Gran Canaria.
I just replace the old engines Cummins V502 for new cummins 6BTA 330 twin disc 1.5:1 with new shaft 45 mm and propellers 4 blades actualy 20x19.
The boat do after last tries, 20knots but need to do more.The engines need to do full power at 2800 turns but goes to more then 3000 turns.I suppose that's the pitch of the propellers who is wrong?
Can you say me the best pitch for the 4 blades prop.
Thank you very much for your help.
Kind Regards
Louis
Hello Sir,
Kind Regards
Louis
- AndreF
Nibral is what it is made from, the best, and of course, the most expensive material practical. There are many manufacturers.
1981 FBC BERG1883M81E
andre you notice your 250hp running 22" pitch and mine at 23" with 330hp .the cup affects the use of pitch quite a bit however the total thrust goes up dramatily due to less airated water .effiency will also increase . i have the same fuel burn as 4cyl yanmars at 24 knots.
Thanks for all of you who responded with the above information.
It seems that Louis never came here as I suggested, and I relayed the info to him you provided. He wrote back to me saying he could not change his props, but it was unclear to me why. He asked if he could repitch his existing props instead of getting new ones with larger diameter and more pitch. I told him I did not think he could increrase the pitch as much as necessary without significantly weakening the blades, and that he should speak with a prop specialist in his area to confirm this.
He then dropped out of sight without answering my last note.
No thank you, no KMA, no nothing. So much for trying to be a good guy!
Frank,
Although your phantom friend may have dropped out, all of the regulars that come to the Discussion Page benefited from the informed comments. Everytime I click on this page, I consider it a tutorial from some of the most experieced watermen/craftsmen assembled anywhere. Thanks for initiating the dialogue.
Tommy
Tommy
We have a Louis as a member on this board......he is the guy that posted pics of a large crane hoisting his boat and positioning it in his yard....then posted pics of a really nice "A Frame" that he used to remove a pair of V-8 Cummins......seems to me that he is in the Mediterranean area around Italy or Greece
Sounds like the same guy to me
Hi to all , and Harry , that Louis is from Canary islands and I am from Portugal , however only now I saw this post cause working times dont let me enough time to read daily. Anyway , I am Luis , the "A frame" guy and my beloved Bertram is slowly getting better. Btw, some months ago I just bough a 1995 Dodge Ram 1500 runing on gas and lpg and its really a nice thing to drive (V8) , I really like V8's. So now I have an american boat and an american truck. I already have the replacing engines for the old V8's - and they are Cummins 6BT-210hp waiting to buy the ZF 45A 1.56:1 - 8º gearboxes as advised here on our Bertram encyclopedia.Harry Babb wrote:We have a Louis as a member on this board......he is the guy that posted pics of a large crane hoisting his boat and positioning it in his yard....then posted pics of a really nice "A Frame" that he used to remove a pair of V-8 Cummins......seems to me that he is in the Mediterranean area around Italy or Greece
All the best for all the faithfull
Users browsing this forum: Bing [Bot], Sweetnut, Tommy and 421 guests
