Anyone know where I can get port and starboard bow lights that fit into the swoopy, razz-ma-tazz bow chock on my 31?
K
Bow lights
Look for ordinary 12v bulb twist lock fittings that are press fit into circular plates. Fairly standard item. Seat them in holes with a clear silicone bed. Drop in red and green plastic pieces with a silicone bead on top and bottom and compress to seal with the screw in top piece of the bow chock. I suggest you lube the component parts with vaseline so as to be able to disassemble when a bulb goes (and they eventually will).
Users browsing this forum: No registered users and 57 guests
