Hard to steer B31
Hard to steer B31
Hi:
I have hynautic steering on my B31m but it steers like a Mack truck.
The fluid is at the proper level and the air pressure too.
Being a new boat to me i dont know the history. I disconnected the tie bar and its still stiff steering. I noticed the previous owner left some automatic transmission fluid in the boat, its red in color. Is this the kind of oil you use in Hynautic systems? And this boat does have auto pilot by Simrad. It steers fine, but stiff as a board.
thanks
bob k
thanks
bob k
It shouldn't be that hard. First of all, if it's filled with automatic transmission oil it shouldn't be. The proper fluid that is red is Milspec 5602 Hydraulic fluid. I just bought a gallon from East Hampton airport maintenance for $29. Buy the clear stuff Teleflex now sells and you'll pay that for a quart. Second, you may have air in your lines and need to have them bled. The bleeder nut is under the reservoir. It should be unthreaded a few turns and have the wheel turned from one side to the other until fluid runs out then tighten. The Hydnautic System is excellent and basically simple. Do your rudders move freely when disconnected from the ram? Walter
Look at your helm closely where the shaft goes into the body.
Your dealing with a stainless shaft and aluminum body. Over time water with helms that are mounted in a verticle orientation water lies on top of the seal area and begins to corrode the aluminum and it powders and expands and acts like a pair of vice grips on the shaft.
I've had to repair hundreds of helms over the years for this reason.
Other than debris in the system and the bronze filter being clogged at the tank, not much else to go wrong if its still stiff after disconnecting the rudders.
You may have to loosen the 4 helm bolts and drop the helm down to inspect the top where the seal is. Most of the time the hole in the dash or use of a dash plate is just big enough to put the shaft thru and not big enough to see anything.
Edit to note:
Most cylinders are brass, but some have replaced them with the cheaper aluminum. The same could happen here as the helm also even though its on a horizontal plane.
Edit to note:
Also check to see if the fluid is a lightweight oil vs. motor oil....no kidding....I blew a hose offshore on my Seastar once and was forecd to use motor oil (Rotella-T 15w40) instead of hyd. oil....worked fine, but VERY stiff steering....drained and flushed with the proper hyd. oil and all was well. I've been told water will work in a pinch as well.
Aircraft Hydraulic fluid
Walter: I can find Milspec 5606 aircraft hydraulic fluid, but I cannit find Milspec 5602. Is 5606 the proper fluid? If not, where did you purchase Milspec 5602.
Fred Haas
Fred Haas
Frederick W. Haas
- Skipper Dick
Aircraft Hydraulic Fluid
Thanks guys! I checked the Sea Star bottle and it says you can substitute aircraft hydraulic fluid #5606, so I guess that answers the question.
Fred Haas
Fred Haas
Frederick W. Haas
Users browsing this forum: Bing [Bot], Google [Bot] and 330 guests
