We have two B33's we are converting over to stainless gas tank. One is a SF. Once the tabbing was cut loose, the tank lifted straight up. On my 1978 FBC, I had to cut out the aft bulkhead to pull the tank. That will be getting glassed back in after the new tank is in. I will only be able to glass from one side so it will not be as strong as the original. The bulkhead was only tabbed to the bottom & stringers. The side ends are free floating as the exhaust run down the sides.
The problem we are having is the ??? of how to restrain the tanks. Does any one know where we can get strapping to secure the tanks. ( And what is the proper name for the strapping)
Al
Securing stainless tanks??
NITES OFF
1978 B33 FBC
Al
1978 B33 FBC
Al
Bill, went to Fraser Welding in Marblehead last Friday. Several people had mentioned that name. They don't answer the fone & no answering machine. Got there & the shop was wide open. No one there & the people next door the the Trading company had not seen the guy all day. Left a note on the work table next to the package from UPS. Still have not heard back. Guess the guy is so busy he does not need any more work.
Walter, where do you send your raft off to? That is something I never considered.
NITES OFF
1978 B33 FBC
Al
1978 B33 FBC
Al
Al,
Mike Fraser is the guy I had originally tapped to do my hardtop. Its not a they, only a him. For a number of different reasons, I wound up going with someone else. My brother has used Mike to do some work on his sailboat. The story I got from both my brother and my cousin Norm is that he does great work when you can get him to work. The problem is that he does a lot of work for the yard where his shop is at.
Regards,
Doug L.
Doug L.
- Dave Kosh R.I.P.
Al,
I used the David Pascoe method for securing my SS aux tank. 1/4" PVC foam board 1" wide as shims all around and under side. Pine epoxied and glassed was used for the for and aft partitians. Whatever method you choose just dont use any metal for securing thta will cause galvanic corrosion. And make sur you coal tar epoxy the tank if you have not already ,2 coats. http://www.yachtsurvey.com/
Dave K
Dave K
Keep Fishing...
Users browsing this forum: Google [Bot] and 52 guests
