Thru Hulls - Assembly question
- Hyena Love
What is the recommended substance, if any, to apply to the threads when screwing hose nipples or hard piping into thru hulls?
I have that magic snot - Tuff Gel - and assorted greases and adhesives. I also have teflon tape like you would use for home plumbing.
Bigger picture - I am doing the internal plumbing to run the restroom/washdown pump and to supply a live well. Thru hulls are already installed with valves (one is 1 inch, other is 2 inches), and I am just doing the internal plumbing.
Thanks.
Thanks.
- Hyena Love
I've always used thread sealant with a lubricant to prevent galling.
If you tighten to proper specs, you'll never lose continuity between parts.
The problem arises from people needing to align pieces and instead of making the effort to tighten, they leave it loose or snug.
All salt water stuff used is bronze or on occasion red brass which is fairly hard.
Standard brass for fuel lines I always use heavy wall vs the cheap crap you get at the box home stores. Good thread cut and pitch is important both on male and female parts. You can't get that with the cheap crap.
I've never rung a thru hull or pipe fitting using 2 14" wrenches to tighten on 1" or above sizes.
If I really wanted to make it difficult for someone in the future, 5200 was used :). Good luck without a torch.
Users browsing this forum: Bing [Bot] and 86 guests
