heat exchanger repair
Have a leak on one of the top necks[at the weld] of my mercruiser heat exchanger anybody tried Marine Tex for the repair or any other epoxy or am I fooling myself and rip it out and send it out?..TXS-Bill G.
heat exchanger
Probably will rip it out I did use some stuff called J-B Weld a liquid cold weld and I seem to remember it worked anyone else ever used it?sold at Home Depot.
JB Weld is a metal filled epoxy and an excellent product. Give it a try again, but be sure to properly prep the leaking spot with a stiff wire brush and wipe it down with denatured alcohol. Build it into a fillet and overlap the spot as much as you can, up to 1/2" away.
Worst case scenario, you'll end up pulling it for a true weld or having a welder come aboard.
I totally agree with the guys that said "Fix it right".....get it silver brazed by a good welder
As far as JB Weld or any other band-aide....in some cases the application of epoxy makes welding a bit more difficult.
ALL of the epoxy MUST be cleaned off of the area to be welded. If JB Weld or Epoxy penetrated down into the crack it will start burning and make a good weld nearly impossible.
It can be cleaned and it can be welded but its more difficult.
Harry Babb wrote:I totally agree with the guys that said "Fix it right".....get it silver brazed by a good welder
JB Weld or any other epoxy is great in an emergency...but glue isn't going to be a long term fix and it will cost you more in the end to have it done correctly. I'll 2nd a good radiator shop...they can clean it, braze it and test it.
heat exchanger
Duct tape it is,pulled it and sent it for repair Thanks!
Users browsing this forum: Google [Bot] and 128 guests
