Has any one used aproduct called easy water. Its a water softner that dosen't use salt.thanks Russ
www.easywater.com
off topic
When I hit a point last year that I couldn't tollerate the high lime content of my well water any more, I heavily researched all of the options, talked to numerous professionals, including plumbers and water treatment engineers and technicians.
Bottom line on these type of units is that they are snake oil... "Don't waste your money" I was told by almost everyone except the guys selling the snake oil.
I installed a Culligan system which loads initially with 160 lbs of salt and have found it very conservative on salt use. I haven't added any salt in close to 8 months and only about half way down in the barrel. Will probably give it a 40 lb boost soon. The water quality of my 200' well is exceptional other than being very hard. The Culligan unit cured that with flying colors and is virtually maintenance free and operates automatically, including the regeneration cycle.
Mine is the Medalist Series, was reasonably priced, good local service, and easily handles the volume of water that I use inside the house.
So, like others told me, I'll say to anyone else: Don't waste your money on the snake oil gizmos.
- Russ Pagels
Users browsing this forum: Google [Bot] and 34 guests
