Transom Rod Holder Spacing
Installing 2 rod holders in the transom and was wondering how to space them. Any recommendations?
Capt DQ is right. The only thing I could add is if you are not sure about the exact spot wait and take your time before you start to drill it out. If the holes are not perfect with the holders in them it will look funny from the dock and you will always see it every time you get on. I speak from screwwing it up myself.
One other thing is if you have a inside transom panel, your rod holders are probaly going to be the straight up holders, not the 30 degree holder because of the panel.
Garry is right, depends on what your planning on doing. If trolling baits or lures they are going to be in the middle of the spread or farther back, just to the outside of the prop wash anyway in that position.
If you use downriggers that works for you also, put your rod in the transom holder & your downrigger on the gunnel holder. Mine are there in that position because it works well for whatever fishing I need to do.
Hope that helps you.
R,
DQ
R,
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
I removed the flag holder from the center of the transom and put in a Lee's 15degree holder in it's place. For some reason though, my transom panel was close to the transom and I still had to cut part of the panel to make the rod holder fit in place. Not too terrible overall, and with my chair and 4 flat line clips, gives me 5 lines off the stern. Double rigged outriggers for another 4 lines giving me a total of 9 lines in the water at one time. Also 2 downrigger mounts on the corners if I want to throw 2 more or 2 of the above down deep.
MAKES A NICE SPREAD!!!!!
Harv
Do you have a chair or fighting post? If so, space 'em out toward the gunnels a little. If not, try three or four spaced across the transom. I troll flatlines out of the transom rod holders. I used rod holders with no angle in the transom. On Storm petrel, I stopped using my outriggers. We routinely fish ELEVEN lines, using only the center rigger!
A good friend of mine bought a boat (38 Luhrs) with no outriggers. He could not get any put on by the time the Tri-state Canyon Shootout began. We fished without them. Fishing 11 rods, we stopped keeping tuna after we had twenty in the boat.
Get the very best rod holders you can afford, such as Lee's. Don't forget backing plates! good luck!
Steve
Steve
Speaking of rod holders, Can anyone suggest a cleaner that will get the black crap off from down inside a Lee holder. The "white don't stay white very long!" I think I have tried everything, beach..Simple Green...etc.
Users browsing this forum: Bing [Bot] and 52 guests
