dytek 500
- Capt.Frank
dytek 500
Anyone have a old Dytek 500 they are not using. I can't read the screen on my gauge. I know they are out of business. I have a hole in the dash to fill.
1976 FBC
3208 NA
3208 NA
If Vics doesn't work try looking at Cruz Pro. You might need to use a piece of Starboard to help fill the whole but they offer a sea temp guage on a stand alone basis.
http://www.cruzpro.co.nz/wtp35.html
Frank - I hooked it up to a battery and it lights up but nothing on the little screen.....I don't have the sensor for it as its installed on AJ....come to think of it, the reason this one is here at home is I replaced the one on AJ because......the screen was blank? I'll be happy to take it to the camp and hook it up to the sensor on AJ and see if it will work...I'm going there today and be back Sunday or Monday.
- Capt.Frank
- Capt.Frank
- Capt.Frank
dug i don`t have the ducer but airmar makes there units for all . the ducer is the size of a quarter and requires a 3/8" hole . superior to to the airmar combi. units that read depth at 50/200hz as well as speed ,temp. ducer is a two wire unit to seperate from all other instuments . normally used by the pro`s looking for small temp. break within a large eddie.very inexpensive but require boat haul.
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
