I installed the PSS on my Bert and was wondering how they keep the water out?
The stainless collar with the set screws is pre-loaded against the black metallic fitting that has the hose barb on it. I have 1.25" shafts and preloaded to 1" as per PSS.
That pre-loading holds pressure against the 2 surfaces and that keeps the water out????
I am wondering if I am understanding the PSS system correctly, my boat is not in the water yet.
PSS shaft seal install ?
- scenarioL113
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
Don't forget about the O-Ring in the SS Collar
But other then that...That is pretty much it, just a big mechanical seal.
A pretty old, rugged and proven design. The big new twist to the old design is the "Black Metallic Fitting". Old mechanical seals use a Ceramic Seal...but the composition of the PSS seal is much much better.
Frank,
The stainless collar and carbon face it rides against is a seal like the ones you find in many water pumps.
carefull ajustment of the ring is important otherwise it will either leak, too loose, or spray water, too tight.
Always make sure when ever installing the collar on the shaft any lubrication is done with liquid soap. Any petrolium products will stop the seal from working.
- scenarioL113
how do you guys plumb the water to the seal. I'm coming off the oil cooler but to prevent water from coming into the boat from the seal do you guys put an anti-siphon loop in the hose or do you just install a shut off. If you use a shutoff since its such a small hose would a plastic valve work or ist that a no no. Thanks
Naturaly if a hose splits or a clamp breaks water will enter.
Being its a 3/8 dia connection its no big deal, but regular maitenance checks should spot trouble before it happens.
Don't try to unscrew the nipple off the seal and install a shut off.
I don't ever remember getting a call back from any install I did with a leak complaint.
Every 5 years change the hose and clamps unless you spot an issue before hand.
Users browsing this forum: Google [Bot] and 104 guests
