glendenning controls
- Russ Pagels
Has any one Installed/used the Glendenning single lever controls?Good,bad, use or stay away from them. thanks Russ
I have installed numerous EEC3 pure electronic controls with no issues.
If your talking about the electronic to the cable actuator boxes then I haven't used them.
GD products to me have all been good with few issues. Certainly much better than the micro commanders or twin disc setups.
I used one of the first electronic setups and sync system on a (31)Cummins QSB when they first came out. It was apparently either a prototype or a trial setup because it came with no instructions for install or setup and I had to figure it out but it all worked together fine.
I have some under the dash pics of the single lever thru the side console installs if you want to see on a 31.
- Russ Pagels
- Russ Pagels
Users browsing this forum: Bing [Bot], Google [Bot] and 32 guests
