Overspray & Racor ?
Overspray & Racor ?
Had trouble finding the Finesse without running all over town so got some McGuires #9 Swril Remover and called their tech people. They said it was about the same as Finesse, so gave it a try. By hand it did nothing to the heavier overspray. Used the orbital buffer with a terry pad. Slow, slow, slow removal. Then tried some old 3M Fiberglass Cleaner & Wax I had used on the hull gelcoat of the B20 and it did the trick with the buffer - took the overspray off pretty quickly and left a high gloss shine.
Question for the Faithful - I have Racor 500s on AJ and one of them has been retrofitted with a petcock screwed into the bottom of the bowl to drain the bowl, and works great. The other one has the original plasic two pc. valve and is leaking and all boogered up. I want to replace the plastic valve with a brass petcock like the other one and need to know what thread is in the plastic bowl. Last week when I had the plastic one out in my hand during filter change it looked pretty coarse like a NPT.
Looks like some bad weather swirling up in the Gulf heading this way.....
UV,
I just changed out my 900's to the petcoks. Racor has a direct replacment and it comes with the seals. I had to change out the plastic bowls as they were old and devolped hair line cracks and split when it screwed in.
I could pick one up @ wholesale from Lewis Marine and bring it to FLL. if you like.
Cheers,
RussP
Cheers,
RussP
KAHUNA 1963 Sportfish
Users browsing this forum: Bing [Bot], Google [Bot], pschauss and 105 guests
