Whats the best product to use after a first coat of 545 primer?
Thanks in advance,
Matt
Pin Holes
- matt ciarpella
- Junior Member
I used the awl fair for pinholes then high build over that, long board fair till flat n smooth, 545 over everything when done..happy sanding. BH
- matt ciarpella
- Junior Member
No such thing...
click on the www on the bottom my response and you will see the answers to many of the "dumb" questions I asked.
Bucket of knowledge is very deep on this site....ask away... BH
Ian, I used ground up corn in a sand blaster to remove all the old paint, then I "CAREFULLY" used a grinder to get the bulk gel off then switched to random orbital. The key is building the finish back..I used 10 coats of west epoxy with moisture additive, then I began the longboarding and fairing, the grinding if not done carefully leaves tons of highs and lows, highbuild and low density filler will become your best friend. I have at least three weeks into fairing the hull.
I am very happy with the out come...flat as a I can get it. Patience and persistence. BH
Users browsing this forum: Google [Bot] and 78 guests
