I was wondering what may be used to seal the rear deck when I lay it back down. There is a material that is very similar to 5200 or 4200 that was used previous. I am pretty positive whatever was used was put there when the boat was built new.
What would be something to seal her up with?
On another note I still have some of the old material that I am having trouble removing, any tips or trick on getting it to peel off from the cockpit?
rear deck is going back in after new tank
- scenarioL113
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
A silicone follow up....... I spoke with the G.E.people when I bought some silicone that wouldn't cure (turned out it had been heated above 80 degrees; who knew?) they told me silicone was silicone. That whether you buy marine, door & window, bath, whatever...the silicone is the same. What do you know about this, Bruce?
- TailhookTom
I'm aboard with the "silicone is silicone" deal. I have started using some stuff called "Kwik Seal" by DAP from the hardware store that is cheap, easy to use, and dries to a nice bright white that does not seem to yellow in sunlight. And once you open the tube the left-overs don't harden like most 3M stuff does. It is advertised as an "adhesive sealant" for kitchen and bath uses and seems to be somewhere between 3M 101 and 4200. Not for use below the waterline, but a really nice product, and the lack of "marine" on the label makes it a helluva bargain.
Users browsing this forum: Bing [Bot], Pete252 and 313 guests
