I remember a post that states the 300 HP Cummins are pretty sensitive to exhaust tempt's above 875 degrees F.
You guys that have the Cummins engines......can you tell me what the exhaust tempt runs at a hard cruise?
H
Cummins Exhaust Tempt
Harry-
I have the 330s and at 2400 RPMs am seeing around 900-925. Harry this is in our 80-90+ degree water. When I was bringing the boat from Virginia Beach in the Atlantic around to Orange Beach, AL last year I noticed a considerable difference in temps after we got in the warmer south Florida and Alabama gulf temps. I wonder if cummins has a chart which factors environmental conditions for these type readings? Also, initially the boat was a little over propped and this really drove the TGT up at high RPMs. I have the ISSPRO pyro/boost gauges. They are excellent gauges to have, and provide some great situational awareness. ISSPRO customer service is good.
-ANDY
-ANDY
Harry,
Things inside will start to go south past 1250 degrees...i.e. melting pistons, etc. If you are below 1050-1100 degrees reading between the manifold and the turbo it will be fine.
Post turbo readings are not as good of an indicator of the engine's EGT. Readings taken after the turbo will be cooler. But, as with all things engines...the cooler the better.
Users browsing this forum: No registered users and 317 guests
