Suggestions for repair?
I have a weep on my steering. Any suggestions on repair? Threads are tight. Do these boxes have internal seals?
You can see a drip forming bottom left of box (left hose only) in picture.
If you remove the wheel and the 4 bolts holding it to the helm it will drop down to allow you to see the shaft and seal and make sure that is where its leaking.
That is the pump of the system. The tank should be somewhere else. Make sure you relieve the pressure(tire valve) before disconnecting the lines and mark the lines as to their position so they go back to the correct port on the helm unit.
If its been together for awhile, spray everything with Corrosion X first. Makes things alot easier and less likely to break when you take stuff apart. If Charman doesn't work out, there's a place in FLA. recommended by Seastar that was great on the phone when I had questions. I can find the name/number if you want it.
- Russ Pagels
Users browsing this forum: Bing [Bot] and 83 guests
