Gas tank?
Gas tank?
Looking to replace my gas tank because I think I might have the great Ethanol problem. ( gotta check when weather gets better) I am here in Michigan if anyone knows how to build the 222 gallon tank. I am running the Merc 454 gassers. Like to have the diesel fittings just in case. Should I go Aluminium, Stainless Steel, or plastic? What are the pros and cons with them? Also who did you guys get your tanks from? Also what gas line should I run? Can I run the -an fittings that are popular with the auto scene? Thanks, Mark
I went with an aluminum tank that I had made by Patriot Marine Fabricating in Forked River, NJ (tel. #609-693-5542). The tank was made out of 1/4" aluminum with 3 pick-ups and returns in case I ever go diesel/get a generator (neither are in my plans). Patriot epoxy coated the tank also. They were great to work with, and I'm real happy with the tank. No problems, nice work, nice people, nice price.
Plastic tanks aren't available in a big enough size, and SS tanks generally aren't CG approved and its difficult to find someone to build them. F'glass replacement tanks that are supposed to be ethanol-proof are or were available but are really expensive--more than 2X what an aluminum tank will cost. I had talked to Richard Kidd at Bertram about a F'glass tank when I was looking last year but I understand from this site that he's not there anymore and that in any event the build time/delivery was at best uncertain.
I also went with a 1/4" aluminum tank, Cheap, quick and i am only out alittle over 2k, The figureglass tanks are mucho expensive, I have come to the realization after talking to many people the stainless steel think is not true. The guy who built my tank said he builds stainless steel tanks for the coast gaurd all the time. I went with a guy out of floridia, cause he was very nice, knowledgeble and cheap. I got my tank last friday, and the welds are beautiful. I will post some pics soon
Matt
Matt
Matt
Hull #315 - 854
Matt
Hull #315 - 854
John F. and I essentially have the same set up except my aluminum tank was built by Atlantic Coastal Welding.
Given that the idiots on Capitol Hill have considered raising the ethanol content I would be a little sceptical as to the future integrity of a new fiberglass tank no matter how "ethanol proof" everyone claims it might be.
Good luck with the project!
Mack
1973 B31 "MAKO"
1973 B31 "MAKO"
I just purchased a brand new Mercruiser 3.0 for my B-20. The book that came with it tells you that it has been made to be able to use E-10 with warnings that all fill, vent and fuel lines must be changed to ones that meet that same requirement. They DO dance around on the potential of E-15 becoming mandated some time in the future. Sure sounds like they didn't plan for the future or the ramifications of a stronger blend to the components of the engine. Real smart. Real Congress material.
Hey thanks for all the replies. I am leaning now toward an aluminum tank. CWJ I have a 79 sportfish model with upper and lower controls. Hopefully will look at the boat this weekend. About another month and a half before she gets splashed for the 2010 season. Just gotta do the rudders shelves for sure before it get wet.
As long as capt. Pat is ok with it
The guy i used is John at
http://www.custommarinefueltanks.com/
I dont konw if anyone has used him or not. But after getting my tank and seeing the welds, I am impressed. Its how i wanted and what i wanted,
Matt.
Matt.
Matt
Hull #315 - 854
Matt
Hull #315 - 854
If you're interested, I believe this company makes fiberglass tanks: www.polyumac.com.
Al
1970 31' FBC Hull No. 315-901
"Teppi"
"Teppi"
- Capt Dick Dean
Hey guys, I'm having Alex W. build me a glass tank. We're getting max volume out of the standard deck height and this tank allows for maximum usage of fuel. It has two sump "pockets", one in front, one in rear. I'll let you know exactly how many gallons I can get into her when done. The resin is the same they use for gasoline holding tanks rated for and exceeding E15, and will last indefinitely. I was thinking of alternative materials until I talked to Alex, I'd give him a call.
Hi Mat, cost of the tank should be around 4K, I know it's up there but this is something I've been saving for to buy outright and also be able to get the maximum usable fuel and longetivity in the future. And also I tend to take to heart what Capt Pat says about going glass on tanks, as he is very knowledgable in many areas, not that it is wrong to go other materials I just like the idea of being able to use the very last drop of fuel the tank has remaining in it, if it ever came down to that.
rocky i always wanted to post something on the subject of underground fuel tanks, we have two 10,000 and one 5,000 gallon tanks for diesel,hi-test,and regular . they are on the waters edge litterally surmerged in salt water. they are double piped with leak indicaters along entire lenth . they are "sticked" every other day . this chemical placed at the end of the stick indicates water in the fuel as little as a teaspoon with cause stick end to change color. sorry for the long post but if i leave out one item people will jump all over your post. why don`t they just dublicate the exact formula new york state mandates for underground tanks? a 250 gallon tank coat $750.00 and there are a zillion of them in ny. what gives?
building the glass tanks for the boats are very time consuming, underground tanks require no baffles and I thought they are mandated that they be changed every certain number of years?
Had there been no ethanol introduced these tanks would still be good, so what worries me is how do you know what will be added to fuel next and its reaction to the current resins used?
This is as we cutting the tank out of a silver anny 31 today
As for who to make your tank, if there are boat yards there are local businesses making tanks, use one of them, its a good chance he has already made a dozen for Bertrams already.
I had my fiberglass tank built by Polyumec. This is the company building them for High Tide Marine and also used by Richard Kidd, before he pulled a fast one on Allied Bertram. Cost was also in the 4K range, and considered completely ethanol resistant up to 100% ethanol. Don't matter to me as I will be switching to diesel once I get my projects in order.Rocky wrote:Hey guys, I'm having Alex W. build me a glass tank. We're getting max volume out of the standard deck height and this tank allows for maximum usage of fuel. It has two sump "pockets", one in front, one in rear. I'll let you know exactly how many gallons I can get into her when done. The resin is the same they use for gasoline holding tanks rated for and exceeding E15, and will last indefinitely. I was thinking of alternative materials until I talked to Alex, I'd give him a call.
Harv
mike the paste we use turns bright purple i agree with the wrong indication can come up for gas but for diesel it is foolproof because the test nipple sits dead center of tank and the marine fuel tanks slant to the center.i will inquire with the fuel delivery driver and suffolk weights and measure on the mandated test stick on ethanol gas. 64 degrees today and the push to drop 1500 boats in the water started.
stations have been using that paste since Noah fueled up the Ark
robbie you cannot imagine the amount of people involve in gas tanks for marine use. epa,dec, suffolk weights/measures,suffolk health,tyree enviromental,uscc,and the worst ny sales tax. major oil spill 1 quart must be reported to uscg in one hour,if not 25,000 first shot.suffolk county inspection at any time water in gas on there equipment 5000,00 first shot.mandated leak detection around and under each tank,all line from tanks to fuel dispenser double piped with leak detection inside outer pipe.vents piped 22' oversea level. very few selling gas on soth shore anymore. incidently if fuel is used in a vehicle with plates on it they will lock down marina and 20,000 minumin fine.what type of fiberglass are the tanks made out of???
Jesus used to own itJP Dalik wrote:Nice to know that Moses owned a fueling stating when Noah showed up with the ARK.
gimmie a break I was in a fog, I spent 4 hours trying to get this stupid tank to peel away from the Bertram, they should have built the whole boat that strong!
Lets paste and glass the crap outta this thing, but lets leave the bulkhead and the subfloor its sitting on and against raw wood.
Users browsing this forum: Bing [Bot] and 47 guests
