Rudder Packing
Rudder Packing
We built the ruder shelves out of 2 sections of 5/8 Coosa as Capt. Patrick suggests in his building tips section and they turned out beautiful. My brother is at the boat right now cutting Coosa to fabricate supports for the mufflers.
We are getting ready to reinstall the rudders and we are looking for any hints/assistance on this task. What kind and size of packing should we use for this? Anything else we should know before we put the rudders back in place?
Thanks again for all of the help.
JR
JR
Thanks Capt. Patrick,
Here's one of the pictures I posted of the rudder through hull:
http://haulout.shutterfly.com/26
We cleaned out all of the old caulk at the base of the rudder through hull and I was wondering what kind of caulk/material is recommended to fill this space. The hole in the hull had to be drilled larger than the through hull to accommodate the two bolts on the through hull.
JR
JR
Capt. Patrick,
I don't recall seeing a rudder backing pad when taking the rudder off. Maybe it disintegrated over the years. Is a rudder backing pad something I fabricate myself, or something I can buy? What kind of material is it made of? Do I place the pad in first, then cover it with 5200.
Thanks for bearing with all of the questions,
JR
JR
I'm surprised by the absence of a backing pad on your boat... The necessity of the pad, (bedded and glassed on to hull), is to increase the thickness of the hull at this critical point and to, as greatly as possible, spread any shock loading over a larger portion of the hull.
The pad, as Bertram built them, was 3/4" marine plywood, polyester puttied down and glassed over lightly. As I build them, either plywood or Coosa board, epoxied down and a heavier biaxle glass over the pad. Same as I do for strut backing. (see: Classic Bertram Strut Problem)
The first diagram, being 2 part, allows you to close the gaps to a minimum around the rudder port as it comes up through the hull.
![Image](http://bertram31.com/misc/rudder_dia.gif)
Capt. Patrick,
Went out to the boat today and found out that a previous owner added a large backing pad that goes from the rudder to the strut. Here is a picture of it along with some pictures of the Coosa Board rudder shelves:
http://haulout.shutterfly.com/41
For some reason the pic of the rudder/strut backing pad will not enlarge when you click on it. The best way to view the pictures is to select slideshow on the right side of the page. I'll add a few more pics once I finish up the rudder shelves.
JR
JR
Users browsing this forum: No registered users and 92 guests
