shut-off for fuel filters
- scenarioL113
Where should I locate shut-off valves on my fuel system.
I have racor 500fg filters and was not sure where to put shut-off valves. This is a new install. New tank, filters lines shutoffs......everything!
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
- scenarioL113
6 in total is correct . generally speaking we find out we have a bad check valve at the worst possible time---------zip----there goes the prime on the high seas well luckely the bertram 31 is a dry boat and never rocks so we will have no problem repriming right. i would put a shut off on each side so even with a bad (this is what usually goes bad on the filter housing) check valve you could change filter and get on your way.
Ok, I need some education here. If the racor is not below the tank but higher up, and you just need to remove the top, pop in a new filter then top off the filter, how would you get air in the line if you have a bad check valve?
Sorry for what may be an obvious question , but I am not seeing how air gets in the line.
it is not air tony it is fuel . you open the top and the fuel from the fuel injection pump line flows out the top of the filter becuse check valve has debrie behind ball seat.then line fill with air.not bad at the dock but a bitch at sea.your making with the wrenches over a hot engine.
Not quite true, Bob....bob lico wrote:captain the valve at the tank outlet is a coast guard issue. like fuel fire on a ship.not maintenance issue.
2008 CFR Title 33, volume 2 CHAPTER I--COAST GUARD, DEPARTMENT OF HOMELAND SECURITY
PART 183--BOATS AND ASSOCIATED EQUIPMENT
§ 183.568 Anti-siphon protection.
Each fuel line from the fuel tank to
the fuel inlet connection on the carburetor
must:
(a) Be above the level of the tank top;
---or---
(b) Have an anti-siphon device or an
electrically operated fuel stop valve:
(1) At the tank withdrawal fitting; or
(2) Installed so the line from the fuel
tank is above the top of the tank; or
(c) Provided that the fuel tank top is
below the level of the carburetor inlet,
be metallic fuel lines meeting the construction
requirements of § 183.538 or
‘‘USCG Type A1’’ hose, with one or two
manual shutoff valves installed as follows:
(1) Directly at the fuel tank connection
arranged to be readily accessible
for operation from outside of the compartment,
and
(2) If the length of fuel line from the
tank outlet to the engine inlet is greater
than 12 feet, a manual shutoff valve
shall be installed at the fuel inlet connection
to the engine.
[CGD 74–209, 42 FR 5950, Jan. 31, 1977, as
amended by CGD 81–092, 48 FR 55737, Dec. 15,
1983; CGD 85–098, 52 FR 19729, May 27, 1987]
captain you can see the intention was gas.(carburator) all diesel engines have electrical operated solonoid valves in order to shut down so before we get into any valves ,the cc requirements are meet with (b) but building a boat we run into # (1) for any fuel engine so the valves on a diesel put on the filters are for maintenace --------------us.
Item A states: Be above the level of the tank top
The next word is supplied by the USCG: OR
Since the fuel tank manifold on a Bertram, (all flavors 31' or less), is on top of the tank and below any filters, pumps, or carbs, technically no valves, of any kind, are required. The regulation is purely designed for anti-siphon reasons. Not whether or not there might be an inconvenient air bubble in the fuel line due to whatever reason, such as opening the top of a Racor or replacing a spin-on filter...
Now does it make sense to the individual boat owner to put valves whever he wants them? Of course it can. You can put a valve at every hose fitting if you want to.
Frank - the Racor 500s are plenty big for the 4BTAs. I have run 500s on my 6BTA 250s for thousands of hours with no problems. And hard plumb the ball valves to the Racors like Patrick says...if you install the Algae X magnetic conditioners, hard plumb them as well into the intake side of the Racor and hard plumb the ball valve to it. Mine are tank valve-fuel line-ball valve-Algae X-Racor 500. No ball valve after the Racor and I've had no problems changing filter elements under way. Just turn off the ball valve, fill the filter body with fresh diesel, screw down the top - and don't forget to open the ball valve (dhhhhhh, me done that?) and go. "Cheating" and not filling the filter body to overflowing 'cause you are too lazy to dig the jug of fresh diesel outta the bilge works about 10% of the time...the other 90% involve the dreaded bleeding procedure on a hot engine.
Bigger aint's necessarily better on fuel filters. The enemy of good is better....
- scenarioL113
Thank you guys for the replies. I will plumb the shutoffs directly to the inlet and outlet sides of the filters. I will also install a shutoff at the top of the fuel tank at the fitting.
I guess it is necessary to mount the filters above the level of the top of the tank????
There is room to do that on my B28 since the engine compartment is higher thank the cockpit.
1971 28 Bertram
4BT Cummins
4BT Cummins
I mounted mine on the rear engine compartment bulkhead with ball valves on the tank side.
Eddy G.
[img][img]http://i232.photobucket.com/albums/ee10 ... C02269.jpg[/img][/img]
[img][img]http://i232.photobucket.com/albums/ee10 ... c01733.jpg[/img][/img]
Eddy G.
frank this should help you.all fuel lines coming from tank should be indiviual runs from tank to engines or generator. like vic roy said all fuel lines go from tank to algae-x to flter to engine or generator. every fitting is hard piped (threaded) no clamps in fuel feed or return. here is tank valves.
![Image](http://i140.photobucket.com/albums/r21/BobLico/fuelfilters002.jpg)
this is the 500 racor for generator . on this filter i used a water moisture alarm. you only need one on any one of the filters . i consider this very important for those who go offshore . water to a diesel is death!!! better you find out as soon as possible to take action.
![Image](http://i140.photobucket.com/albums/r21/BobLico/fuelfilters001.jpg)
Are these the fuel hose yall are using, atleast the parker version of the aeroquip
Parker 221 FR
221 FR Transportion - Marine Fuel and Engine Hose
SAE J1527 Type A. Class I, USCG SAE J1942. Application: Gasoline, ethanol blends, diesel fuels, petroleum base hydraulic fluids and lubricating oils. Inner Tube: Synthetic rubber. Reinforcement: One braid steel wire. Cover: Synthetic rubber blue. Temp. Range: -4° F to +212° F.
Parker 221 FR
Matt
Hull #315 - 854
Matt
Hull #315 - 854
we are fortunate to have a shop on the water that contructs" water taxis "for fire island transportation. the coast guard inspects and gives a bill of approval each year because it carries passengers much the same as 31 bertram with "6 pack " charter lic. the parker number you have there is correct for cc acceptance we use aeroquip fc332-10 rated 250psi .this is the blue pipe you see in bruce`s installation.barbed fittings are used for non-essentials salt water washdown,bait tank feed , fresh water, etc. the outside surface will crack in time and then leak with barb fittings and regular hose. no big deal on non- essentials ,just cut off 1" and redo but fuel-----------not cool man
the outside membrame of the parker is a smooth slick surface and the aeroquip is course almost like a cotton fabric texture . they both last a lifetime. the boss man here will not install any fuel pipe with barbed fitting. we had 4 boat fires in 10 years attributed to hose, and the police try to incriminate the gas jockey for cutting loose a burning boat and kicking it away from the dock.he save the marina from preventing the fire from getting to the gas pumps but scpd. did not look at it that way.coolair this is 2010 times have changed you either deal with fuel injection gasoline or fuel injection diesel making the return to tank with pressure the hose starts pissing gas at a hose barb connection at the tank return and you have a disaster situation .
coolair just consider this fact while you mill over the price of threaded hose fittings; for 2008 --80 boats burned with 2 deaths and 51 injuries unfortunally most of those injuries are bad burns . this is the coast guard report for fuel system fires and ignition of vapors only .fuel system failure rates right behind sinking in claims. not a rosey picture . a few less dollars for beer money put into the fuel system is well spent.
Users browsing this forum: Google [Bot] and 131 guests
