Hey Faithful - sanding away on the old 13 Whaler. Will be ready to put some Interlux Pre-Koe primer on next week, then follow with the Interlux Brightside finish cut a little with their 333...Question of the day: do I cut the Pre Kote or use it straight?
Got my Bondo skills back up to snuff, great stuff.....some of the nooks and crannies around and behind the "wall" inside the transom required use of a little sandblasting to get the chipping old paint off. Amazing what a lot of time, patience, & money can do.....I never had this much time to do fun stuff when I was working. I now realize Work Sucks.
More paint advice needed
UV,
If you're applying with a brush, Pre-Kote requires thinner INT0333, same as you'll use for the Brightside. Since it's a one part paint, allow a couple of days for an average coat to cure before sanding. Sand with 220 grit.
Pre-Kote isn't intended for below the waterline use. (contains microspheres which can absorb moisture if submerged.)
APPLICATION AND USE
Preparation:
PREVIOUSLY PAINTED SURFACES: Sand old surfaces with 120 grade (grit) paper. Remove sanding residue. Wipe with Brushing Liquid 333. Repair surface defects with Surfacing Putty 257. Sand surface, wipe clean.
BARE WOOD: Sand with 80 grade (grit) paper. Wipe with Brushing Liquid 333. Repair surface defects with Surfacing Putty 257. PLYWOOD: Follow directions for bare wood. Apply Inter-Prime Wood Sealer Clear 1026. MAHOGANY Follow directions for bare wood. Apply Pre-Kote directly to the wood.
BARE FIBERGLASS: Wipe a small area with a clean rag that has been wetted with Fiberglass Solvent Wash 202. While the surface is still wet, wipe with a clean, dry rag. Continue this process until the entire surface has been cleaned. Sand with 80 grade (grit) paper. Wipe with Fiberglass Solvent Wash 202. Repair surface defects with Interfill Epoxy Filler. Sand surface, wipe clean.
Method: Apply 1-2 coats. Depending on surface condition. Allow the necessary overcoating time between applications. Sand between primer coats with 120 grade (grit) paper until translucent. Remove sanding residue with a rag dampened with Brushing Liquid 333. Apply finish coats. Sand with 220 grade (grit) paper between Pre-Kote and finish enamel.
APPLICATION AND USE
Preparation:
Users browsing this forum: Google [Bot] and 31 guests
