capt.pat
trying to find the steering helm that you use the most of ,was it the hynautic 60 series? if so where can i find it at ?or is there another one that you like for space ?
phil
steering helm
Phil,
The H25,($593 list), is my preference. It's a 2.75 cu in displacement with a 1" straight 6 1/8" shaft and is mated with K1B ram, ($828.90 list), for 4 1/2 turns hard over to hard over.
You'd also need a RV55 resovervalve, ($565.65 list) & the SS ball joint for the ram end, ($123.85 list). This system is rated at 500psi and will accept nylon hoses. I prefer to go with standard heavy duty hydraulic hoses though... Your hoses can be made up locally at your friendly NAPA or CarQuest parts store.
Total list, less hoses & hose fittings: $2,111.40
You should be able to order through Byfield Marine Supply in Pensacola, FL. 800-237-3741
If they don't have what you need, check with Lewis Marine SUpply, Ft. Lauderdale, FL 800-327-3792
If you strike out with both, I can order through my Lewis account... I think my price would be around $1,700.00, but I'd have to call Lewis and check...
Users browsing this forum: Google [Bot], PeterPalmieri, pschauss and 336 guests
