Generator Space Question
Gentlemen:
As we get pounded in the Northeast with more snow I am dreaming of warmer days on the water in LBI. In any case, I have a 1963 31 with twin 454's. I installed AC and now want to install a generator. The boat is in NJ and I am in PA and I mis-placed my mesurements for space between engine and side of hull. Does anyone have those measurements or models that will fit? I am looking at a westerbeke and also a Kohler 5E. Any thoughts or guidance?
I did put a Westerbeke 5 KW gasoline genset on the outboard side of DeNadas port engine.
It was tight but I did not have to remove any engine parts to get her in place.
I did install a remote oil filter......you'll never get to the filter as close as it sits to the main engine.
I liked the Westerbeke generator. It was an 1800 RPM unit and very quiet. I only had one problem and that was because I did not follow the instructions in the installation book.(at that time I was much smarter than the book....but not any more LOL)
Trying to save a nickle I used a main engine battery as a starting battery for the genset. It went fine until one day the generator was already running when I started the port engine. The generator sensed a surge and blew a fuse.....then the generator governor could not control the engine and it would go into an over speed condition and shut down when the AC compressor shut off.
I like to have never found the fuse but after replacing it and installing a dedicated battery (like the instructions said) we were whole again and the unit ran flawlessly.
The 5 KW genset is freshwater cooled. I believe the model was a BCG.
I do not care for the 3.5 KW Westerbeke gasoline generator....its an outboard motor belt driving the generator.....seawater cooled.
![Image](http://i147.photobucket.com/albums/r289/chip51maker/DCP_2639.jpg)
![Image](http://i147.photobucket.com/albums/r289/chip51maker/DCP_2640.jpg)
![Image](http://i147.photobucket.com/albums/r289/chip51maker/DCP_2637.jpg)
Nothing to it Rawliegh
All you have to do is drydock the boat remove both cylinder heads, then crawl up thru the exhaust.....change the plugs then reassemble the whole thing....LOL
Can you tell that I just took my smart ass pill for the day.....
Actually I never got to that point before I started the repower, but I am pretty sure you are correct.
It only took about an hour to unhook and remove the genset if needed, but I believe that the plugs could be changed without doing that...but it would be tough.
I am sure the genset would have to be removed to change Exhaust manifolds.....just the price you have to pay when you put 5 pounds of crap in a 3 pound box.
H
H
Users browsing this forum: No registered users and 195 guests
