Moderators: CaptPatrick , mike ohlstein , Bruce
STeveZ
Posts: 239 Joined: Jul 4th, '06, 08:16
Post
by STeveZ » Jan 27th, '10, 16:43
I need to replace several of these deck hatch drain fittings.
Are they for sale anywhere?
Are they easily made w/ a ball bearing and a big hammer?
Is there some other fitting that has superseded these?
Thanks as always for your help.
Posts: 3785 Joined: Jun 29th, '06, 12:04
Post
by Bruce » Jan 27th, '10, 17:17
Got a flaring tool?
Standard copper tubing with a flare.
STeveZ
Post
by STeveZ » Jan 27th, '10, 17:36
I'll get one, thanks!
IRGuy
Posts: 1767 Joined: Jun 29th, '06, 07:48
Post
by IRGuy » Jan 27th, '10, 19:00
I made some out of PVC pipe and a couple of flanges.
mike ohlstein
Posts: 2383 Joined: Jun 29th, '06, 11:39
Post
by mike ohlstein » Jan 27th, '10, 22:08
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
Posts: 3435 Joined: Jun 29th, '06, 08:30
Post
by Rawleigh » Jan 28th, '10, 12:13
Pvc pipe faired in with epoxy will last longer.
Rumrunner
Posts: 75 Joined: Jul 24th, '06, 21:00
Post
by Rumrunner » Feb 5th, '10, 23:14
The best tubes are 1" transom tubes used on outboard boats with drain plugs. They are available everywhere including WEST. The flange is thin and the tube is stainless. The thin flange makes draining the water better. A thick flange leaves water around the edge. I have tried many different things and this type of flange is the best.
Capt Tom
Capt Tom
Charlie J
Posts: 2207 Joined: Jun 29th, '06, 09:14
Post
by Charlie J » Feb 6th, '10, 07:43
tom
never thought of that, will have to give them a try, mine always get clogged with fish scales
Users browsing this forum: Google [Bot] and 178 guests
