Tiller arm
Tiller arm
Hi guys, question for ya about my B28 style tiller arm (below the shelf) on the starboard side, when I tighten the pinch bolt, the arm has some play on the rudder shaft. In fact I can actually slide it a bit up and down on the arm. Can I safely grind some material off at the pinch or slotted portion of the arm(.025"), or do I have to replace the arm? Port side is O.K. Thanks.
I am sure that removing even as much as 1/8" (.125) of material to gain more squeeze is not going to compromise the integrity of the tiller arm.
You probably have WEAR that is preventing the arm from clamping onto the shaft.
You may consider getting some .002" or .005" Brass shim stock from the autoparts store and inserting a strip of the shim stock between the Rudder shaft and the Tiller arm to take up space instead of widening the slot.
Harry
Harry
Rocky:
I know Harry knows more about metal working than I'll ever dream to know, but I would look closly for a crack in the clamp portion, to be on the safe side. I had a tiller arm that seemed to clamp down fine and looked fine, but seemed to get loose when I checked them in the spring. I found out the hard way, when a vessel cut across my bow in the Woods Hole channel and I had to go hard reverse to avoid it. Well I stopped in time, but it sounded like I hit a rock. The hard reverse sucked the rudder 180 into the prop. Made a mess of prop, rudder, and shaft. two weeks of boating lost and lots of money. I bought two new tillers from buck algonquin.
Scott Traenkle
Ken , drilling a hole through the rudder shaft seems like it would severly effect structural integrity of the rudder shaft, and what happened to Scot was his tiller sheared at the clamp, letting the rudder turn into the prop. Ouch! I actually checked my tiller for cracks the other night, I do not see any cracks so I will take a small amount of material off the pinch point. Thank you though, for your thoughts.
Users browsing this forum: Google [Bot] and 196 guests
