upper helm ignition on/off circuit
Hi guys, just thought I'd say Hi and to ask, what typically shuts off the engines from the upper helm, the coil power circuit(gas) or the entire dash supply from lower helm? I know there is a "Bertram" circuit diagram out there somewere but I do not have one. There is a provision for two switches under steering wheel above the little doors, I'm assuming that is where they were. I would imagine you would want to be able to shut them down from up there, esp. in an emergency!
Thanks Rocky.
Thanks Rocky.
- Skipper Dick
- Skipper Dick
Rocky,
I do not have a lower helm, but I do have three separate battery switches. There are separate banks for the port, starboard and house and they are maintained separately by an isolator. The switches that control the power for the engines are located on a panel beneath the hatch that is beweeen the engines. I have it set up so each battery switch will operate from either battery bank or both, just in case one bank craps out on me.
I do not have a switch to tap into the house battery incase they both crap out, but I can change the lead to the engine switches in a matter of a few minutes in case that unlikely scenario happens.
This is sometime a pain in the ass. My fuel gauge is located on the starboard instrument panel and only works if I have the starboard switch on. I have my fuel monitoring system tied into the port panel and have to switch the port battery switch to on just to monitor the starboard engine. I'll solve these little irritations later this winter when it isn't so hot to work on the boat.
Dick
Dick
Thanks Bruce, I think I will run my switches as an interupter Before the lower helm supplied power so it kills everything from up top, (P and S being seperate switches of course).
Rawleigh, yes I would greatly appreciate that diagram! Even if I don't keep OEM, it is nice to know how it was done.
gareism@aol.com
Thanks again, Rocky
P.S., We've decided to keep our B31, Thank God!!
gareism@aol.com
Thanks again, Rocky
Users browsing this forum: Bing [Bot], Google [Bot] and 176 guests
