I have a single 330B Cummins with a Morse control. Can't maintain RPM's a cruise. Is there an adjustment on the Morse control to stiffen this up? There are two set screws on the lever but they don't seem to do much for tension.
Jim
Throttle creep
adjustment screw
not sure what type of morse controls you have...but if they are the chromed version with the small name plate that is held in place with 2 screw (name plate says "MORSE CONTROL" on it), then they are like mine. I had same prblem. You can remove that name plate by removing the 2 screws holding in place. Inside there, you'll see two more screws. One adjusts the "throw" and the other "friction". If you tighten up that friction lever you're problem will go away. (at least it did for me). It can really drive you nuts!
Joe
Joe
Users browsing this forum: Google [Bot] and 468 guests
