When trying to upgrade the pole holders we found water had seeped into the gunnel and rotted away the wood core in the surrounding area. Some only an inch or so all around was wet and we figured let it dry out and fill with Marine-Tex and refitt. But in two spots the damage goes several inches deep (maybe 6")...a bit much for Marine-Tex or Fiberglass.
I read the Tips Section about Core Damage...but working upside down in such tight quarters makes core replacment pretty difficult to say the least.
Any suggestions on a good way to fill and seal up the area, making it strong enough for some HD Pole holders and not have to worry about voids or shrinkage...I had though about injecting foam or fiberglass with filler to avoid heavy shrinkage...but I am really just guessing.
Advise for Buddies boat, Rotted gunnel core
Make sure that at least the area through which the screws go is thoroughly filled with epoxy so that it cannot compress. Dig out as much of the rotten wood as you can before filling. If you can cut/gouge out the bottom layer of glass and the wood behind it you can fill it and then epoxy on a plywood backer to cover the filler and strengthen the repair. Unfortunately it will continue to rot if any moisture is left in there.
If I read you correctly, you might be able to repair it working from the top. remove the holders. Fashion a tool to dig out as much of the wet wood as possible, as far as you can go. Let it dry out. You can help that out with a hair dryer or heat gun on low. When dry, mix a batch of epoxy (I use the West System for simplicity of batches) with vermiculite which you can get in any plant store or florist. Mix to a fairly stiff consistency and pack into the void as tightly as possible ( I am assuming there is a fiberglass top and something on the bottom). If there is no bottom, create a temporary one covered with waxed paper or Saran wrap so it won't stick. Once the epoxy/vermiculite mixture cures, you can fine seal the exposed areas with a mixture of epoxy and faring compound mixed to a peanut butter consistency. Once that's cured, sand, drill, reinstall, etc. I might reinstall the holders with some bedding compound and some epoxy on my screw holes or better yet, through bolt with backing plates. Walter
walterk wrote:If I read you correctly, you might be able to repair it working from the top. remove the holders. Fashion a tool to dig out as much of the wet wood as possible, as far as you can go. Let it dry out. You can help that out with a hair dryer or heat gun on low. When dry, mix a batch of epoxy (I use the West System for simplicity of batches) with vermiculite which you can get in any plant store or florist. Mix to a fairly stiff consistency and pack into the void as tightly as possible ( I am assuming there is a fiberglass top and something on the bottom). If there is no bottom, create a temporary one covered with waxed paper or Saran wrap so it won't stick. Once the epoxy/vermiculite mixture cures, you can fine seal the exposed areas with a mixture of epoxy and faring compound mixed to a peanut butter consistency. Once that's cured, sand, drill, reinstall, etc. I might reinstall the holders with some bedding compound and some epoxy on my screw holes or better yet, through bolt with backing plates. Walter
Thanks Walter, think this is the way I'd prefer to go.
Yes the area has a glass layer on the top and bottom...the Plywood core between them was wet and rotting. I say was as when the new holders where being installed we found wet wood and pulled out all the wet wood. Then drilled some holes underneath to get some more air in there. Sealed the top so water would not get in. It's been a couple weeks drying and now to finish the repair.
He went with Pompanette holders with the backing plates. All SS, nice holders...
Users browsing this forum: Bing [Bot] and 204 guests
