batteries??
batteries??
ok
time for new batteries, have twin gasers, currently only have 2 batteries i know i need atleast 3 banks, but give me time just got the boat in april. but any opinions on AGM or jsut go with standard lead acid old school battiers
thanks
thanks
I needed to redo all my heavy 12 volt engine room system and replace the two 8D engine starting batteries (I have Cummins 6B diesels) last year. I did a pretty exhaustive battery comparison and asked a lot of questions here and in other forums. I eventually went with 2 AGM Group 34s to replace each old lead/acid 8D, plus I added two more 34s for house power and generator starting. Expensive, but I wanted to have the best source of engine starting power I could find. I had space for two 8Ds, and found with the AGMs Group 34s, three of them fit into one 8D space. So I now have two 34s for starting each engine, and two as house power, all where the 2 8Ds had been.
It suprised me in the answers I received to my questions how varied the respronses were.. some guys like standard lead/acid batteries, some like AGMs. The middle of the road gel cells seem to have fallen by the wayside for marine use.
I am happy with my new system, but lots of guys buy lead /acids and are happy too. I supposed there might be a difference it how long each type lasts.. but that depends on how you use them, and how you recharge them. I suspect this is one of the subjects where everybody has their own ideas and all systems work fine if they are installed and maintained properly.
I have a rather lengthy write-up on my new 12 volt system, including pictures and layout drawings that I can email to you. If you want it let me know.
- AndreF
Do a search of the site, there's a ton of discussion.
I switched out my 8D's for Odyssey dry-cell batteries. They are sealed (clean), smaller, lighter and easier, my 2 cents.
1981 FBC BERG1883M81E
- ZeroCavity
I have an 8d sitting in my bilge for the house bank and one starter battery for each engine. One alternator charges the two starter batteries though a combiner and the other alternator (100 amp) takes care of the house loads.
My 28 likes the weight of the 8d down low and the two starting batteries I consider consumable so I get the small cheap ones and they get tossed every three or four years.
In my gas B31 I have two Exide Orbital AGM batteries. they look just like Mikey's Optimas. They are going on 7 years old and still working. I will need to change them as a precaution soon though. I use a Xantec Trucharge 40 battery charger and leave it plugged up most of the time. Yo7 need a charger with an AGM setting to use them though.
This question always results in many answers......
If you spend a bunch of time in rough water, the glass mat batteries will probably last a bit longer. They can take the pounding quite a bit better because there are no plates to break. If you spend most of your time in the bay, they probably aren't worth the extra money.
For an off shore boat without a gen-set, the cats arse would be two AMG starting batteries, and two 6 volt AMG golf cart batteries wired in series for the house.
Coolair;
Sorry I didn't respond when this was originally posted. Missed for some reason. I glassed a piece of plywood and glassed in place. Added some stops to hold the batteries in place and added straps to hold'em down. Works well and they are out of the way and low in the center of gravity department. Good use of a space that ends up being used for things that don't need to be there.
Users browsing this forum: Bing [Bot], Google [Bot] and 404 guests
