non-skid repair
non-skid repair
Hey,
i dont know if yall have seen this before, i just discovred it the other day and seems pretty cool to me, i know i have a few spots on my engine covers that need fixing, the problem is i dont know which pattern to use, i guess they can tell you if you call.
http://www.masepoxies.com//Videos/NON_SKID_REPAIR.html
I have essentially stopped using West Epoxy and shifted over to MAS Epoxy.
I have called both companies on occasion, and have received good info and assistance from each. I believe Capt Pat when he says all epoxies are pretty much the same, and certainly West has a broad following, probably larger than MAS Epoxy has today.
After reading a MAS Epoxy ad in an online boating magazine I decided to buy some of their products and found them to be somewhat lower in price than West, but they were only available then from Boater's World, not at West Marine (no relationship between the two companies). When BW went belly up West Marine started selling MAS Epoxy.
There are two differences between the two companie's products, one small and one very important.
The West resins and hardeners are sold in metal containers, the MAS Epoxy products are all sold in plastic. The West hardeners over time undergo some type of chemical reaction I assume with the metal can, which causes the material to turn a reddish brown. I don't know if this effects any of the cured material's properties, but it looks bad when you first pump the hardener from the can.
The major difference that caused me to "standardize" on MAS Epoxy is that their epoxies, when hardened, have no amine blush.
BTW.. I have found what I believe is a test to determine if there is amine blush on a cured epoxy surface. Touch it with the tip of your tongue.. If amine blush is present you will know it instantly.. it tastes awful!
Just my opinion.. for whatever you think it is worth.
Ian...
Your comment reminds me of a story, but I definitely can't repeat it here. Maybe the next time I am in the UK I will look you up and tell it to you in one of your local pubs over a pint or two!
Users browsing this forum: Bing [Bot], Google [Bot] and 326 guests
