CX again
CX again
Have one of those cheap Wal Mart window a/c units in the shop with the electronic controls. Compressor hung up and would run all the time, even with the unit shut off. Had to unplug from the wall to get it to stop. Figured either the compressor relay or the electronics that tell the relay to relay was hung up. Whole deal is pretty much sealed so you can't get at anything. Doused everything with red CX last week. Today it came back to life and works fine...... Creepy stuff.
CX
Hi Vic
I have read many of your post about the success stories using CX. I also think I remember that you offered to sell CX to B31 members. I would like to try a can on my stuff. If you have CX to sell please give me a call or email me at hbabb@bsmachineshop.com. Tell my secretary that the call is Boat/Bertram related. CX sounds like it works on everything. I once heard about a woman that used WD40 for arthritis
Harry Babb
251-928-5291
Harry Babb
251-928-5291
I can back up the CX stories. Engines submerged in salt water. Sat of months and rusted up tight. Saw rear bracket for mounts and said to myself....self, must have. Sprayed em, busted them loose, and made them look like new, and now they are holding up my new engines! The stuff is worth its wieght in gold. Hope it does the same thing for getting my props off if need be. Kevin
CX
Hi Vic
Today I received the shipment of CX that you sent to me. Thanks.....Good thing that I asked for 2 cans.........my son took nabbed one can before I even knew that it arrived.
Harry Babb
Harry Babb
I am waiting for someone to proclaim the ultimate!
I can see it now...
They are having challenges with the wife. They have been trying for a baby for months, but to no avail. She has tried all the tricks, and so has he.
Finally, he comes into the room with the big red can.
He sprays her from head to toe.
Wham! She is pregnant! With his child!
Miracles can happen...
I can see it now...
CX
Patrick,
I used some stuff made by OMC back in the 70's & 80's that I think was called Carbon Remover and I though it was good but I am really anxious to try this CX. I have been watching CX post for a while and am surprised at just how many uses you guys find for it.
Now for you Dug........the possibilty of using it as a fertility compound....that scares me to death. If there is even a hint of a possibility that your idea may work I will have to totally restrict my wife from boarding my boat, but on the other hand if I spray down my B31 do you think that I may find a B28 in the slip next to "DeNada" the next day ! ! Ha Ha
I have several OLD outboard motors and one of them is stuck. Tonight I will spray CX into the cylinder and will let you know the results later.
Harry Babb
Harry Babb
Users browsing this forum: Bing [Bot], Google [Bot] and 48 guests
