Hancock's Half Tower
Stage is set for a dry fit on Hancock's half tower... Tower weighs in at just over 200# and the new boom extension has been tested to 300#, actual load limit is around 400#
Yup, JP, it finally actually got here............
Now thats a cherry picker....Texas style...are those plumbing fittings? When you work alone you get pretty creative...and THATS creative.
Bob,Now thats a cherry picker....Texas style...are those plumbing fittings? When you work alone you get pretty creative...and THATS creative.
The hard top is bolted down to the pipe with 1/4" machine screws. I removed the 4 corner bolts for the bridle points. I TIG fused 1/4" hex head bolts to 3/8" bolts, head to head. The pipe bushings are just spacers because the 3/8" bolts weren't fully threaded.
I built the crane originally to be able to remove the old gassers and install the 4LHA Yanmars, but the reach wasn't long enough to accomodate the tower, so added an 8' extension that bolts up to the original end. I welded a reciever to the end of the extension and mounted a 2,000# ATV winch.
Got an associates degree in Redneck Engineering from UofH...
- JohnCranston
- JohnCranston
nah...........its about getting the job done. it dosent have to be pretty.......its just in patrick's case............... it always is.tunawish wrote:Hey Randall
It's true what you say about Capt. Pat. it's absolutely amazing the stuff that comes out of that address..
But kinda makes you wish you hadn't posted that re-torquing trailer pic about now doesn't it....!!!!
LMAO
Ray
i'm known in some circles as the worlds foremost expert on the use of duct tape. (upgraded recently to "gorrilla" tape)
Looks like he nailed it Capt.
Go over any of the electrical connections that were made as they will probably have a standard butt connector with no shrink tubing.
Regarding the aluminum plate- this is the finished product (early in the project) we talked about yesterday (no through bolts to hold water and scrape your head on). The other thing is that down the road you may need to add some support on the rocket launcher. You can see the 2 legs that were added on ours (barely). We carry mostly 50's and 80's and withouth the extra support there was a noticeable "harmonic"
Rawleigh,
From the other images it does look a bit delicate... To make the extension I used three 8' sections of 1" schedule 40 steel pipe bundled and welded. A fourth piece of pipe is captured mechanically and tensioned to act as a torsion bar on top. This configuration changes the downward force from straight down to oblique through the length of the bundle.
All and all, it handles the weight of the tower without even working up a sweat...
Well, the redneck cherry picker, dubbed by Bruce, & better known as T-Rex, worked flawlessly to hoist Hancock's tower onto the boat. This was a prefitting run to mark the necessary placements and drill the holes for the wire chases. Two guys helping, up, positioned, drilled, marked, and back down in under 2 hours...
Damn shes a good lookin boat...
And thats saying something if it's still in the ugly duckling color scheme.
Pretty sure my heartrate increased a bit looking at the pics. Gonna be an incredible 31.
- chris pague
- scenarioL113
Users browsing this forum: No registered users and 100 guests
