Are wet exhaust manifold repairable?
I have one that has a crack on the top that was only seen when it was boiled out at the machine shop.
My intention is to throw it away but before I do I was wondering if anyone has successfully repaired one.
It is a B-series cummins 4 cylinder
Repair Exhaust manifold?
- scenarioL113
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
I thought about it a little more.....make sure that it is indeed a crack and not just a surface defect in the casting.
It will not hurt anything to grind a little and see if the "Crack" goes away. In other castings I have seen surface defects that may look like a crack...but were not.....you can also Dye Pen test it....a lot of welding shops and machine shops have the dye pen test kit.....not expensive at all to have it Dye checked
Harry
Harry
Users browsing this forum: Bing [Bot], Google [Bot] and 45 guests
