Is it the site or my computer?
Suddenly many of the postings, including mine which seem to be fine when I'm typing them are coming out so wide that I have to shift the post from side to side in order to read them. Anyone else having the problem and is there a way to cure this? Walter
Walt,
The only time that happens is when someone has posted a gigantic image that is wider than than the screen resolution & size...
Walter,
If your note was for say on the B31 center console thread, that had a couple of large images attached to it. Then you would see the left to right toggle. If like in this thread where there are no images posted you should be able to view the whole box.
If that's not the case it may be in your box.
Users browsing this forum: No registered users and 50 guests
