Before I reinvent the wheel I thought I'd solicit ideas from the braintrust.
What do you recommend? and no, I don't have a spare $1,000 right now.
![Image](http://www.thehulltruth.com/attachments/test-area/78783d1246331659-bimini-bert_elec.jpg)
Frank, See: Links and ImagesBTW.. If you tell me how you posted the above picture I will try to post a pic of my new panel here
[/url]# Designed for twin engine configurations
# Provides 24 hour circuit protection
# Provides main DC circuit protection in addition to high ampere load protection
# Protects electronics from sags and spikes caused by engine cranking
# Allows emergency cross connect between isolated battery banks
# Isolates the Engine circuit from the House circuit
# Simplifies battery switch operation
# Allows independent battery discharge
# Addition of an Automatic Charging Relay automates charging both batteries
Thanks - Just confirming before I start laying down the cash...IRGuy wrote:Jeremy...
I don't think these fuses are anything special.. I have looked at thousands of them in power distribution systems in factories, hospitals, and hotels all over the country. They probably aren't built to marine standards, hence the corrosion, but they did a passable job. As I told you, there were two of them in my boat when I bought it. I suspect they aren't poing to make a surveyor happy if he saw them. Your Blue Seas panel is what you want.. they make top line stuff!
Users browsing this forum: Google [Bot] and 41 guests
