GROUNDING OUTRIGGERS
What is the correct way to ground outriggers?..................txs-B.G.
Bill,
The reality of it is that given the shear emf of a lightning bolt, you couldn't put a large enough system to be 100% effective.
Flat copper ribbon and a cintered bronze ground plate, both of which have surface area which is what you want are the proper materials.
But I've seen the best lightning protection systems completly fail and fry everything.
If your talking for simple anti shock hazzard a #6 wire to your bonding system will work but make sure the rigger has the stainless metal wire connectors between sections as most have nylon insulators holding the sections and pivot point bolts.
Use one of the base mounting bolts as a ty in. Most are of the flat or oval head type bolt using a counter sink base hole. Remove the anodizing from the counter sink(if your base is aluminum) as this can be an insulator and don't use caulk on the bolt head taper as this will also act as an insulator.
Use caulk on the backup flat washer to seal out water.
This effectivly isolates mulitple sections and mountings.
Users browsing this forum: Google [Bot] and 129 guests
